My 1978 GMC motorhome
Possibly. The tanks are less than 7" deep, so I would actually just try an use bolts. It might require some additional frame crossmembers, but that is the leading idea in my mind as well. I'm concerned about rubbing through the plastic with that idea as well...
Could you not simply use padded straps? I don't know what area you have to work with, but I’m thinking something like fuel tanks straps.
Reactions: NashvilleTJ
If you make platforms cover them with cork. For your freshwater you'll want to completely encapsulate it for freeze protection and darkness to prevent algae.
Reactions: Mike_H
While I'm waiting for my new tanks (about two weeks still) We've been working on some of the interior stuff. The bathroom was the source of a lot of discussion back and forth. They are VERY small in an RV, and exceptionally so in a GMC. Ours is bigger, since its a "dry" bath instead of wet, like most of them. What that means actually, is that the area for the comode and sink is VERY, VERY tiny, and it has a VERY, VERY tiny shower in it. We kicked around the idea of 'reinventing" it, similar to this one.
But we couldn't come up with a good way to keep the shower water where it belongs...plus I have enough projects on this thing. So, we decided, for now, to keep the bathroom set-up the same. Maybe a future project...
As was most of the 70's the bath tub, toilet, and sink were all Harvest Gold. After 45 years, Harvest Gold is a really dark color. Our color pallet is much lighter for this project. The toilet has already been replaced with White, and Sinks are easy to swap...But how the hell were we going to change the shower color?
We tried a new (new to us anyway) produce from Rustoleum and used white epoxy "Tub and Tile" paint to paint the shower stall. After some "learning" we got it to look really nice. Updated the fixtures and bright white paint made a world of different in this shower that is smaller than an old school phone booth. No before pictures, unfortunately.
Have you looked for a sink-toilet combo? You might find something that would work for you and open up a little space.
Or the timeless prision daycare unit, sure to be a favorite of the wife. ;)
I found one of these for sale at an antique festival last year. I seriously considered buying it for my garage, but couldn't justify $400 for it. If only they had a pic of Capone or Dillinger sitting on it...
I hear those are great for making wine.
We haven't. The reason the sink is against the wall (like in the example pictures) is that the wheel wells and all the plumbing returns to the tanks are buried back there too, so that bump out is there, regardless of how things are arranged.
Reactions: Wildman and BlueC
Are you thinking about going with those colors in the bathroom? They look really nice and clean.
We have an iridescent tile for the bascksplash/wall, but its a darker silver vs that aqua marine. I'm not the color dept, my wife does that, so I'm just getting the big stuff neutral for now, so she can get her accent colors in. I'm thinking the walnut will be part of it, our couch is a coffee brown. The vinyl I'm using to trim out the cockpit is an offwhite, and our cockpit seats are a light gray. The Ceiling and plastic trim on the roof is white as well. So far, everything works together in my mind...we'll see what happens when its all crammed into an 8 x 26 space.
Reactions: toximus
If you have any yellowed plastic I have a trick to fixing that, I did our RV shower when we first bought it, it had yellowed, especially near the top, from being parked in the Arizona sun. I also fixed the slide trim strips. the process is called Retro0brite and uses hairdresser's cream peroxide, UV light and time.
Wish I knew that before I painted all that plastic trim I have.
My waste tanks showed up yesterday on a big FedEx Truck!
Spent most of the trying to figure out how to mount these, then getting material, holding them in place, and rethinking my whole mounting process. I DID get the big tank mounted and removed again so I can paint the straps. I ended up going with 2 x 2 x 1/8 Angle. The angle is mounted to the cross members and supports the bottom and sides of the tank. I have two supports right now. I have enough material to add a third, if necessary (like if the center of the tank sags).
Got the tank right where it needs to be. Astute observers might notice the sawdust and new hole...Well, I failed to notice this tank is about 10" longer than the old one. No issue fitting it underneath, but when I told the company that made the tank where I needed my fittings to be, I dimensioned the openings off the closest end from each hole...not from one corner, like I should have (and know better). Not a huge deal, I can make it work. Thankfully it doesn't interfer with anything.
And some terrible pictures underneath. Looking at the third picture, I guess I'll have to further modify that cross member too.
And, got my straped deburred, removed pointy corners, and welded a couple tabs on. They are ready for to be cleaned up and painted.
It’s hard to fathom working on something this big, Mike. Kudos to you.
I always tell people, its like restoring a classic car and building a house at the same time. It's daunting and there are days when I just can't bring myself to work on it. Its a constant "pressure" on my psyche, knowing that any time I'm doing anything else, I'm NOT working on my motorhome. I don't have any real timeline though so the only pressure is what I apply to myself and the desire to actually go camping, LOL.
I got the big tank "permanently" mounted today. Cleaned and painted the angle I used to hold it up, then added some cork/rubber gasket material to keep the plastic from rubbing against the steel.
And this ol girl (not what I said in the moment) decided to throw me another curve ball. These tanks are just enough different from what came out that everything is becoming custom and nothing is bolt in (kinda like my jeep at this point).
After getting the black tank installed, I started working on the Gray tank and immediately noticed an issue. The new black tank has the outlet more toward the center of the coach than the original. Its not much (maybe 1.5"?) but its enough to stop my progress again...
To be honest, I suspected this might happen. As soon as I noticed that the cutout in the cross member didn't line up with the outlet, I was worried. I was hopeful, but worried. Today confirmed my suspicions. I should have enough room to run a couple elbows to jog the pipe around the corner of the gray tank, but I don't have them and no one around here actually carries a good selection of 3" ABS DWV pipe. So, I'll order a few different elbows (45s and 90s) to make sure it will work.
Unfortunately, I can't just move the tank over...Where the inlet comes through the floor is VERY close to the edge of a wall. Moving it any more toward center will put the inlet into a walkway. The inlet is also very close to the edge of the tank, already, so its not like I can move it closer to the edge to move the tank starboard.. If the elbows don't work, I'm going to have to get weird...I might have to run a pipe under the coach and add a bulkhead fitting to my new tank.
Reactions: Rickyd
Wow...been a minute. Life Happens, I guess. TBH...I kinda got sick of the MH for a while. Plus we went on Vacation, I went on a wheeling trip, and my wife was gone for the whole month of May. I'm back on it again though. Got my second tank mounted this week and worked out my plumbing solution. I need to post up some pics of that. It actually came together really well, and much better than the old set-up was. I do still need to fab a couple brackets and things. I need to make a mount for the waste valves, so they are just hanging there by the pipe and a couple zip ties (like the old ones were :rolleyes:). I also need to fab up a cross member reinforcement to replace and strength the 15 or so inches of steel I cut out to deal with the big mistake I made not giving the tank company the correct measurements (well the measurements were correct, they just started from the wrong spot since the tank is bigger).
The manufacturer's do a terrible job on supporting tanks and valves, I added support straps to the ends of my hookups because they would move around in the Fernco when operating the dump valves. Many years ago I was dumping the black on my Lance truck camper and the rubber Fernco popped off the tank. The entire black tank emptied in about 1 second. Fortunately my arm was the only thing that got hit by the flying poo mixture.
I'm working on AC mods, I fixed the plenum to eliminate the turbulence and direct the airflow into the ducts. Kool RV makes a kit but it won't work on my model so I made my own. I also have a Micro Air Easy Start arriving today or tomorrow, and I cleaned the evaporator and condenser. In about 3 weeks we leave for the coast, up around Malibu. Dragging the Jeep behind.
Reactions: Mike_H
