Another edition of Fix it better than it was...I replaced my DC electrical distribution "panel" tonight. Replaced the old, loose, and corroded connections with a bunch of new Blue Sea stuff. I'm a big fan of marine style electrical in an RV.
Here is my old set-up. Glass fuses!
And the new stuff. I used the same base plate, but removed the hinged cover because all my new stuff came with their own covers. All my wires not have terminals to prevent stray wires, they are all crimped properly and heatshrinked. I used an ANL Fuse holder with a 50A fuse to protect the system. The coach also has a 50A fuse at the start of the main supply run. Then the protected wire connects to the fuse block, which distributes the power to the individual circuits through standard ATC fuses (not the dumb little glass tubes anymore).
When I'm plugged into Shore power, the charger/converter supplies power to the distribution block and charges the batteries. It has internal protection (plus I am installing a surge protector on my shore power connection) to prevent wiping out the coach 12v system, so its safe to wire direct vs going through the 50A fuse.
I'm about 90% done. I see there is one ground that needs to be covered up (missed the heatshrink). My charger/converter wires also need some bushings. The old way it was connected was just bare wire pushed into the terminals on the charger. The "attachment" was just a dogpoint set screw...well, that doesn't work all that well. I gave em a little tug and they pulled right out. I think I have some bushings I can crimp on so the screw has something to bite against.
The inverter was also installed haphazardly. There are like three splices where its pulling its 12v power...and it was connected on the unprotected side of the fuse. I'll run some new primary wire, all one piece, to provide power to it. Then I gotta figure out how its providing 120V AC to the coach. From what it looks like, its going to the outlet the charger/inverter is plugged into and bypassing any type of circuit breaker protection! I think its only 1500 watts too, so it won't run much. I may just pull it out and install a decent one.
Finally, I need to make some labels. The fuse block came with a sheet of them. I'd like to figure out how to run it through my laser printer for nice, neat labels.
