BJ deletes - in my opinion - are wastes of money... If you're running an axle where OEM-supplier balljoints are failing at such an accelerated rate that you are looking for some fancy aftermarket solution, you're running too small an axle (or too large a tire).I am a member of a BJ delete group and 1ton jeep group, but havn't seen much for the SD axles. Lots of D44s, D30s getting it done. Maybe the BJ isn't that much of an issue on the SD axles?
Most people just cut them off. Unless there is something new on the market, all the popular trusses for the 05+ SD axles require cutting back of the short-side casting, exposing more tube. Most guys that ran the 99-04 Dana 60's (really 02-04 D60s) also trimmed the short-side casting back to exposre more tube.the worst thing about that SD 05^ is that monstrous link knob hangin right off that diff.
i haven't looked for a how to remove them, the series b4 had that nice little leaf perch that was easily concealed in a truss, but like mentioned not the same big UB.
With Eric and Erik's failure - I believe it was the weld that failed in both instances. Eric had his done by a well-known local shop and Erik is a fabricator with years of experience welding onto cast and used all the proper heat and cool-down methods. His experience matches what I've seen on other similar types of failures. Certainly not my area of expertise so I really can't add too much info that except for when the time times, I'm doing the non-weld 13-bolt shaveI’ve also wondered about the bottom of that shave caving in and contacting the ring gear. The Ballistic Fab kit I used has a 1/2” plate, so we’ll see how well it holds up.
Wonderful views! We have a plant in Cortez, CO (close to Durango) and it's one of my favorite places to go check up on. I take every opportunity I can to drive up there We are one of the few permittees that can drive a vehicle in the Canyon of the Ancients (you can see the pipeline on the left of the image below)Then came Cinnamon Pass. Gorgeous views, and quite rocky in places with many ledges and cliffside drives. Although I'm not sure all the pics are of Cinnamon, here are a few from along the way:
Milwaukee sells a 12 volt charger.So could you run a cordless tool battery charger off that thing? I have wondered from time to time about a permanently wired cordless tool battery charger in the back of the Jeep somehow...
My Denali has a 110 outlet that is supposedly 150w max... not sure if it would work with a power drill either though.
Thanks for that info, PC. Since I'm trying to match my rear 68" WMS, I may be looking at the 99-04 if I build it myself. I would definitely go with the 35 outers, or maybe stick with the RCV's I currently run.BJ deletes - in my opinion - are wastes of money... If you're running an axle where OEM-supplier balljoints are failing at such an accelerated rate that you are looking for some fancy aftermarket solution, you're running too small an axle (or too large a tire).
Regarding the balljoint concerns on the SD axles - they're huge and been shown to be reliable for even JKU sized rigs on 42" stickies without much issue. Even the earlier, non-SD Ford Dana 60's (which use the same balljoints as the 99-04 SD D50 and D60s) are notoriously beefy and the knuckles have much less issue than the earlier Ford KP knuckles.
IMO, the worst thing about 05+ SD axles is the WMS width (72") - it can be quite wide for a TJ/YJ trying to stay on somewhat narrow trails. The 99-04 axles are narrower (69.5") and don't require as much prep work, but don't have the OEM 35-spline outers (though easily converted) and have smaller axle C's, which limit u-joint size. Not a problem for most folk, but those looking for +40" stickies with a V8 may lean toward the 05+ SD axle.
And I gotta say, the Mrs. Grand Cherokee Limited is a nice ass ride... Wish she sprung for the Limited-X version (with the Hemi) but it is still peppy enough not to make me hate it, with more than enough comfort for long road trips.
What width is your current prorock front axle? Id probably be interested in buying your housing. I'm trying to figure out the best path for me to get currie Dana 60 outers. The jk44 outers are proving to not be up to the long term work of 37s.Thanks for that info, PC. Since I'm trying to match my rear 68" WMS, I may be looking at the 99-04 if I build it myself. I would definitely go with the 35 outers, or maybe stick with the RCV's I currently run.
My best case may be to widen my current ProRoc by about 4.5" - I just don't have a way to do the required tube work myself (requires a giant press, as I understand it). Or, maybe look at getting a ProRock housing, tubes, and inner C's from Dynatrac and swapping everything over with new shafts.
(Or, maybe just buy a big f-ing press... )
By the way, I wheeled with Chris (92 Vegas YJ over on JF) at AOP a few weeks ago. He tells me you did the wiring for his Magnum conversion, and speaks very highly of the work you did for him.
63.5"What width is your current prorock front axle? Id probably be interested in buying your housing. I'm trying to figure out the best path for me to get currie Dana 60 outers. The jk44 outers are proving to not be up to the long term work of 37s.
Have you considered the Dana "Builder Kit"? Last I checked, you can get them as complete or stripped as you need: https://spicerparts.com/builder-axleThanks for that info, PC. Since I'm trying to match my rear 68" WMS, I may be looking at the 99-04 if I build it myself. I would definitely go with the 35 outers, or maybe stick with the RCV's I currently run.
I saw on his FB page that he was getting it all dialed in... I have been busy with packing and my LJ stuff that I haven't check in with him in a while. Glad to hear it's running strong!By the way, I wheeled with Chris (92 Vegas YJ over on JF) at AOP a few weeks ago. He tells me you did the wiring for his Magnum conversion, and speaks very highly of the work you did for him.
Well wtf there must be a story behind that. Lol63.5"
Not really - that was dynatrac's standard WMS for a ProRrock 60 into a TL/LJ a dozen years ago. The rear I just replaced was that WMS as well. That width was fine until I went to coilovers, at which point I had to add spacers.Well wtf there must be a story behind that. Lol
At the time I was running 3.5” backspace Spydertracks, so that helped. When I went to coilovers, the problem was the top of the rear tire contacting the top of the rear coilover at full articulation. That’s what drove the need for the 1.25” spacers. The front was never a problem. Ironically, to also run the spacers in the front to keep a consistent track width, I had to stretch the front to clear the rear of the fender at full stuff / full turn. That was quite a job.Seems crazy skinny for 40's. I rub on tub with 37s and 65wwms
this is part of the reason i'd just do full hydro. dump my crap gear loose the link make a push forward a lot easier. i'd have to make the same room in the back of the fender to go bigger than 36-37".I had to stretch the front to clear the rear of the fender at full stuff / full turn. That was quite a job.
Yup - that’s exactly what‘s driving me to full hydro. That, and I want my hardcore buddies to stop pointing and laughing…this is part of the reason i'd just do full hydro. dump my crap gear loose the link make a push forward a lot easier. i'd have to make the same room in the back of the fender to go bigger than 36-37".
