You guys may know how much I like my tools, so I though you would get a kick out of this. My mom sent me a power turkey carver, so I had to give it a shot.
Happy Thanksgiving!
Jeff
Happy Thanksgiving!
Jeff
At least now is a good time to buyWell, with Covid I found myself with little to do after my wife and I had Thanksgiving dinner, so I figured I'd relax in the shop for a few minutes (can you feel a sense of foreboding?).
There was some damage on the differential case, but I thought it was superficial and didn't think much of it to tell the truth. I'd planned to throw a file at it to make sure all was smooth and be done with it. So I did. But while doing so I noticed one of the bolts securing the cylinder cap to the case had been sheared off. And the other bolts were loose - 3 were missing the retainers.
So I popped the cylinder cap to remove the broken bolt and I found this: one of the four tabs on the piston (the black piece in the picture) had broken off.
And when I looked more closely, I could see that the case is cracked right where the bolt head was sheared.. Tough to see in this picture, but it's there.
And that was not it. The case is cracked in three places - here is another:
But the worst thing is, I needlessly spent $22 at Northridge for the shim kit and o-rings. Turns out, both of those things come with a new locker....
That's a good thought, Rick. The down side is that if I go that route, I'm still stuck with the semi-float axle - and I've killed three of those already - all before the Hemi. I'm giving serious thought to biting the bullet and replacing the axle. Maybe a full-float, low pinion 60, or something like the Rock Jock Hi-pinion 70 full float and 40 spline shafts.Damn Jeff when you FUBAR something up you don't do it halfway...
My ARB was able to be repaired when I FUBAR'd the case.
Since you're at this point and you need to get a new ARB maybe you should contact Carl Jantz and find out if you can put the Dana 70 R&P into you housing? Then either send the gears you just bought back and get a Dana 70 R&P or hang onto them for your front?
I know you were worried about it not fitting BUT? Reading his description you need 3/8" clearance around your Dana 60 ring gear for the Dana 70 ring gear to fit.
He also sells a load bolt like you were talking about the Currie Rock Jock axles have.
Jantz Engineering: Jana Load Bolts (jantz4x4.com)
Not trying to add more to your project but if it'll work you gain strength in the Dana 70 R&P..
Thanks for the reply, Rick. Comparing the strength of the DT HD60 to the Currie RJ70 - I have no actual idea. And I can't really find any actual comparisons. My gut tells me that apples to apples - meaning both hi pinion or both low pinion - the 70 is stronger. Comparing the hi 70 to the lo 60? Not sure. I do know that when I bought my pro-rocks a dozen years ago Dynatrac told me that the hi pinion 60 was 20-30% weaker than the lo pinion 60. So who knows - although the 70 has a load bolt which supposedly helps the HP a lot.That's all some mighty BIG & HEAVY thinking you have going on there. And having the fuel tank thrown in there just makes it even harder to really make the right choice.
My first concern would be is the HD60 going to be strong enough? I'm gunna say YES but I don't know that 100%.
What is the strength of a RockJock 70? Is it stronger than the HD60? And then the 14Bolt?? Where does it fall into the strength of the other two choices?
If the only choice is the HD60 without having to redo your fuel tank then I'd maybe look that route.
I know back when I was looking at options TeraFlex use to offer full float kits for the CRD 60. I don't know strength wise or anything else as to how well they work. But if you could convert your current axles even if you needed to remove the ends to have have spindles welded onto. Then go with either HD gears or Dana 70 gears & a 4 spline ARB while keeping your current axle?
Now if none of that would work I'd look into the the HD60 first and then the 14 bolt and the RJ70 last. Can you get hubs drilled in the 5x5.5 BP for these axles? Which of the 3 require you to change out your fuel tank? Which of the 3 is the strongest? Which of the 3 can you get hubs drilled to match your current BP?
Sort of sucks that you are only putting a band=aid on on your current setup but I understand.
I think in this case I'd have to make me a flow chart with the pluses and minuses listed on it. And include what would be required to run each axle.
I sure hope so. I think the one I had was a high pinion locker. So, 20-30% weaker...Awesome. Glad you got it so fast. And you have the new design locker too. Wonder if it is any stronger than the other one?
And don't forget to use the left hand fitting wrench for installing it. I'm told that adds 5-10% strength to your install.I sure hope so. I think the one I had was a high pinion locker. So, 20-30% weaker...
