Hi Folks,
I am having some issues with my 2004 42RLE with 105K miles. Have to notice that in last 6 months I was having issues with engine running hot (root caused to be bad water pump). ATF+4 level is really just a little bit overfilled (half quart maybe).
I have multiple issues with it:
1. When it is hot mainly, sometimes it does not engage in Reverse. Like I am switching to reverse from drive, and it behaves like it is completely in Neutral. No noise from Shift Solenoids, nothing. Like the shift position sensor didnt pick up that it is supposed to be in Reverse. Does not light the check engine light and does not throw any codes. Never had any problem shifting into Drive, Park, Neutral, 1 or 2. Only into reverse, mainly when shifting from Drive. If i would hear shifting solenoids but somehow it would just slip, I would blame anything other than the shift position sensor, but it seems like the computer simply does not pick it up that it is supposed to be in reverse. Shifting to park or neutral and bringing it back to Reverse always solves the problem. Shifter linkage cable seems completely fine.
2. When it is really hot day after very lengthy fast driving (like 80MPH on highway), sometimes it slips when accelerating from red light to a hill.
3. The shifts are strange and slow, much worse when it is hot.
4. Once in a while it suddenly clunks, with feeling of knock, happens when driving on 45MPH plus, like it pulls the vehicle back. Feels like it doing some kind of wierd shifting.
5. Fluid is much darker than a new one. Was not that dark by far a year ago.
6. When I trying to reverse Up a Steep Hill, there is a shudder like the entire rig is vibrating and like transmissions is going crazy. Feels much less after regearing (4.56 gears with 31x10.5 inch Goodrich tires), was much worse before regearing.
I am planning to do the following:
1. Install the Derale cooler from Jerry's post - in process.
2. Install GlowShift transmission temperature gauge - in process.
3. Replace filter inside transmission - already got Mopar original filter - Hope that i don't find there any chunks of metal.
4. Install external transmission filter - https://www.amazon.com/dp/B000CJ25PC/?tag=wranglerorg-20. Not a must, but I just want to do it. I saw some folks installing one.
5. Drop Valve body. Clean and replace whatever needs replacement. Planning to do it myself, watched the youtube videos and read the FSM and think that I can handle it myself, w/o paying a shop. It is not my daily driver, and I dont mind it staying inside garage for some time. Try not to use any external shops as a matter of old school principles.
6. Might take it to external transsmission shop to relearn clutch volume indexes, although the above listed does not change anything clutch index volume wise. I saw an old post from Jerry where he mentioned that he didnt have to relearn the CVI after the Valve Body area work.
I need your advice on the valve body parts, that I need to deal with when I am dropping it:
- The Solenoid Pack itself. Is it the right part? Should I take something else? - https://www.moparpartsdepot.com/oem...sZXImeT0yMDA0JnQ9c3BvcnQmZT00LTBsLWw2LWdhcw==
- Manual Valve Lever Sensor (supposedly this is also a temperature sensor with a thermistor that reports to TCM the ATF+4 temperature) - I suspect that this is the guy that is not detecting that it is supposed to be in reverse sometimes - https://www.moparpartsdepot.com/oem...sZXImeT0yMDA0JnQ9c3BvcnQmZT00LTBsLWw2LWdhcw==
- TransGo Shift kit for Non-VLP transmissions - https://www.amazon.com/dp/B009SOVRGU/?tag=wranglerorg-20
- Transmission Oil Pressure Sensor - I understand that our non-VLP 42rle does not have a pressure sensor, it is for JKs only.
- Input and output speed sensors - I can replace these easily, they are mounted externally, but I don't know whether it is really necessary.
- Replace whatever seals needed.
is there anything else that I should be looking into? Any advice from the wise? Want to do everything I can before deciding to replace the entire transmission. I kind of expect the internals (clutches, suns, Torque Converter) to be in a good shape at 105K miles.
