I’m trying to figure out a sound coming out of what appears to be my rear, driver-side wheel when I make left turns on the street. I'm sure it happens on the trail, but it started happening since March, and I haven't taken it anywhere. It's a 2006 TJ Rubicon 6-sp 4.0L, 5.5” long-arm lift (4-bar link in the rear) on 35” tires with 1.25" wheel spacers. I didn't do the original lift, but I've learned a lot about it over the last 2 years. It sounds like the brakes are rubbing, like a metal-on-metal sound, but I'm fairly confident that's not it. Here's what I've tried in tracking it down, but I'd love some new ideas.
Thanks for the help,
Chad
- Only on left turns, indicating an inward force on the bottom of the wheel is pushing the wheel into the axle. Does not happen on right turns at all.
- Occurs at low and high speed (like a roundabout circle)
- Once in a while, I think it happens when I hit a bump
- The lugs on the wheel and spacer are not loose and I re-torqued them evenly.
- The disc brake pads have plenty of life and the caliper mounting bolts are torqued down properly
- Pulling the hand-brake at speed doesn't cause the sound but does slow down the vehicle
- I've checked bolts on the rear sway bar and suspension arms to see anything loose. There could be wear in a bushing.
- I don't see any wear marks inside the tire/wheel or wheel well that might indicate a tire is rubbing somewhere
- I had a bad seal on the passenger rear shock, but that's been rebuilt and wasn't the cause.
- With the wheel in the air, it doesn't appear to have noticeable play when shaken by hand (either top/bottom or side/side)
Chad
