So on my TJ I have added LED tailights, side signal (changed to 3 wire), front signal and headlights.
I had everything working until I added the 2 wire marker light in, ended up shorting something out accidentally and now my hazard lights, marker and signals are all dead. No constant 12v or pulsating 12v at any of the front signal light wires with corresponding switches on (ignition also on). Before this happened my tail light marker or indicating light worked with the lights on. Now they do not, they only light up with brake lights pressed.
Did I fry something in my multi switch or is it something else? I have a multimeter and know how to test just not sure where to go.
After all of this I did some research and ditched the 2 wire marker and now have 4, 3 wire turn signals sitting in the Jeep. Heres my plan for how they will be wired once I restore power back to the signal lights.
Another major question I have is regarding daytime running lights with Led headlights and how to make that work. My TJ came with DTRL and with the lights off the lights will flicker, switched on low and high beams work just fine.
I think I have heard of guys wiring in led "modules" if I'm remembering right or inline resistors.
Im getting it inspected for salvage so I need all the lights to work as they would have came factory. I really appreciate any help or insight you guys can give me!
