Thanks @Jerry Bransford, not exactly the reply I was hoping for!You have the 32RH automatic which is NOT a good transmission for fording water. Its vent hole is on the front of the transmission 2-3" above its input shaft and that area is easily flooded with water so water could easily get into your transmission through that vent hole.
The only way to get around that is to drop your transmission, seal that vent hole (like via TIG welding) and then drill and tap a new vent hole in the top and attach a vent hose to it via a barbed fitting threaded into the housing.
I wouldn't drive a TJ with a 32RH transmission into water as deep as you're describing. Water inside an automatic transmission is a death sentence unless drained, completely flushed, and refilled immediately after getting water inside. It's not worth the high risk of this happening based on your description of what you want to do.
Thanks very much for that - a most useful read.
Thanks - that is very helpful. Unfortunately the 32RH transmission seems to be the weakest link, I'd not expected that!Here is a good write up on waterproofing -
https://wranglertjforum.com/threads...r-tjs-under-hood-electrical-components.19051/
I got my first jeep - '99 TJ Wrangler with 32RH Auto. Eager to drive it to the camp after rain and high water to check the camp. Now I can finally do that because I have a Jeep! Water in the transmission, two tows, and the tranny Just cost me $3,000.00. I'm ill . . .You have the 32RH automatic which is NOT a good transmission for fording water. Its vent hole is on the front of the transmission 2-3" above its input shaft and that area is easily flooded with water so water could easily get into your transmission through that vent hole.
hey JB this might be a stupid question but why not just do that with the existing vent hole ?You have the 32RH automatic which is NOT a good transmission for fording water. Its vent hole is on the front of the transmission 2-3" above its input shaft and that area is easily flooded with water so water could easily get into your transmission through that vent hole.
It has been done there before, here's a thread on the subject. https://wranglertjforum.com/threads/vent-relocation-32rh-auto-1999-tj.51349/hey JB this might be a stupid question but why not just do that with the existing vent hole ?
Not for many of us.Or, while the transmission is down, you could just replace it with a manual instead! Problem solved plus massive upgrade to the Jeep
You knew this was coming!Or, while the transmission is down, you could just replace it with a manual instead! Problem solved plus massive upgrade to the Jeep
Not for many of us.
A lot of the manuals have similar vents. The NSG370 vent is right where the shifter tower assembly bolts to the transmission case. That said, it isn't too hard to attach a hose to it.Or, while the transmission is down, you could just replace it with a manual instead! Problem solved plus massive upgrade to the Jeep
Exactly, the AX-5 and AX-15 have open vents on them. They don't have remote vent hoses like newer transmissions do.A lot of the manuals have similar vents. The NSG370 vent is right where the shifter tower assembly bolts to the transmission case. That said, it isn't too hard to attach a hose to it.
