Everyone thank you for replying, with Both drive shaft and pinion reading zero extending the lower control arms the arrow points down and the opposite when making them shorter so I think it doesn’t matter if it’s up or down as long as both measurements are from the same direction, I also used a 24” carpenters level to check the needle bearing cap was level side to side with the floor as slight differences in that angle affects the reading same as when lining up the angle finder on the driveshaft. So I think it’s reading correctly if the needle bearing cap is the exact same angle as the pinion using the magnet.
just getting back from a test drive I have no vibration until over 65 mph and it feels like that’s in the front, yesterday the pinion was almost a degree up (way I’m measuring if it’s correct) and I was getting some small vibration around 45mph. I believe the vibration now is just coming from the front I can feel just a little rhythmic vibration in the steering wheel not so much from the rear of course it’s difficult to tell exactly my castor is set someplace around +2 to +2.5* The way it handles on the freeway is acceptable for now. I’m in need of shocks and between the aggressive m/s toyo tires and the roads here hard to be 100%
toward the end of next month I’ll have the front hub manual lockers installed and know for sure front or back I’m now just trying to get it so I’m not doing any damage making a run to Arizona on Monday
