So a little over a year ago I bought my TJ (4.0) with a cracked head, the engine had been rebuilt 11,000 miles earlier but they used the original head which must have been cracked, or cracked later. So the shop that did the rebuild installed a new Clearwater head supplied by me.
Potassium levels went from 1800 to 139 to 42 to 26 with successive oil changes. At first I changed it at 175 miles then every 700 miles till we were down to 26ppm in September with 1,000 miles on that oil . Figuring it was residual I drove on that oil for another 2,000 miles then changed it and sent in another sample. Much to my surprise the sample came back with 58PPM, so apparently there is still a small amount of coolant getting in.
What's next? Is it possible the shop damaged the head gasket? I know they used Felpro including new bolts (well, they said they were going to use new bolts). I don't have a problem pulling the head myself and replacing the gasket and bolts, I can do it in my garage and take my time to get everything right.
What would you do? I mean, unless I am missing something, how hard can it be to properly install a head on this simple engine? I'm having a hard time imagining how they could have screwed it up, and the deck should have been checked at the machine shop when the engine was rebuilt right?
Barring a cracked block is there any other place coolant can get into the oil on the 4.0?
