New starter body is making contact with flywheel
Ok update on the Jeep, pulled the transmission and the entire clutch was connected inside the bell housing!!! All of the bolts for the were completely off of the flywheel!! Working on this issues as we speak.
  • Wow
Reactions: Steel City 06
Update on the piece of Jeep. Fixed the clutch and bleed the slave cylinder, everything is back together. Went into 1st and reverse. Now the 4wheel drive is stuck in 4wheel drive. Fixed that and now the Jeep will not move once in any gear. So short end is, when I let off the clutch the Jeep doesn’t move. Any suggestions?
If it turns out to be the shifter causing the issues, consider replacing it with a cable shifter like the Savvy shifter.
https://savvyoffroad.com/product/sav-231s/It eliminates the complex shifter setup and replace it with a more modern shifter like you would find in a new JK or JL. Not only is it much easier to adjust, shifting effort is greatly reduced, and it is not affected by body lifts or driveline position modifications.
