That's the wide angle lens I took it with. Trying to get everything in there. He's a flat lens pic for ya.Looks like the transfer output is dropped too (I only have a phone to use. So I may be completely mis-eyeballing it)
pinion angle too high, as mentioned beforeThat's the wide angle lens I took it with. Trying to get everything in there. He's a flat lens pic for ya.
Checked with an analog angle finder today and got roughly the same angle with both. Maybe 1/2 a degree difference if any. The shaft read 16 1/2 then 17 1/2 the 17ish. The diff read 16 1/2 every time. My angle finder sucks. So with them being so close, should I raise it or lower it (shorten or lengthen upper arms) slightly to see if it goes away? Also does this shaft need to be ballanced?
the pinion angle should be lower by a couple of degrees because it will rotate up higher under power the front DS does the opposite when engaged.
Pinion angle was 0 degrees. It vibrated. It's now down to 3 degrees still vibrates. Are you saying the angle out of the transfer case is too high for the double cardon end?pinion angle too high, as mentioned before
No, that end should be fine, your Pinion should be pointing a little lower than your DS. I use the mounting surface of the yoke to measure, you should be able to get your angle finder on the edge just make sure it’s rotated so you are getting a plumb measurementPinion angle was 0 degrees. It vibrated. It's now down to 3 degrees still vibrates. Are you saying the angle out of the transfer case is too high for the double cardon end?
