JakeHitman Member Joined Aug 29, 2019 Messages 49 Location Washington Jun 10, 2020 #1 I have a lt285/75R16 tires on my TJ. I was wondering what should I put my tire pressure at while on the road? thanks
Kaptainkid1 TJ Enthusiast Joined Aug 19, 2019 Messages 587 Location Los Angeles Jun 10, 2020 #2 26-35psi for street use and off roading air down to 12-18 psi.
Mr. Bills Raconteur Emeritus Supporting Member Joined Nov 24, 2017 Messages 4,190 Location Area Code 605 USA & Código de área 415 MX Jun 10, 2020 #3 I would narrow the range a bit and guess that 28-32 psi would be the sweet spot for that size tire on the highway. Every jeep will be a bit different - pick a pressure somewhere in the middle of the range and experiment up and down.
OP JakeHitman Member Joined Aug 29, 2019 Messages 49 Location Washington Jun 10, 2020 #4 Thanks for the advice. I’ll see what I can do.
rasband Dickhead 🍆 Supporting Member Ride of the Month Winner Joined Sep 11, 2018 Messages 9,071 Location Highlands Ranch, CO Jun 10, 2020 #5 I have a very close size and am happy with 26#, but definitely experiment
jjvw useless stäff member Supporting Member Ride of the Month Winner Joined Feb 17, 2018 Messages 26,449 Location Colorado, USA Jun 10, 2020 #6 I ran mine at 25-26psi for many years.
Goatman TJ Expert Supporting Member Joined Apr 23, 2019 Messages 5,041 Location Upstate NY Jun 11, 2020 #7 If you are getting good wear with no oddball patterns or cupping then you are in the right zone. A bit less psi will help to soften the ride. A bit more may help it roll easier.
OP JakeHitman Member Joined Aug 29, 2019 Messages 49 Location Washington Jun 11, 2020 #8 I’m going to try 27 psi and go from there.
