First off, I think I've read everything available online about 42RLE shifting issues, PCM problems, Wranglerfix fixes, etc. Unfortunately I haven't seen anything similar to the issue I've been experiencing, which brought me to become a member of this great forum (long-time lurker).
My '06 LJ experiences a hard 1st-2nd shift/shudder only after warmed up. I've read that most shifting issues occur on a cold start, but mine only occurs after about 10-15 minutes of driving. Until then, the transmission shifts fine and there are no issues. When everything does get warmed up, the 1st-2nd shift is hard and I can best describe it as a shudder you feel through the accelerator pedal. All other shift points are fine.
The other odd aspect is that if I accelerate really slowly, 9 times out of 10 the issue does not occur. Alternatively, if I accelerate quickly (for a Jeep) it is more noticeable. I've also noticed If I anticipate the 1st-2nd shift point and back off the accelerator right when the shift happens, the issue doesn't occur.
Lastly, to throw another wrench in this, a few weeks ago I started experiencing the classic PCM issue. The engine would rev to 2.25k/2.5k RPM in 1st and then slam into 2nd. I pulled the battery cable overnight and this issue hasn't occurred again, but the usual shifting issue remains. I should add that the transmission fluid is still in relatively pink/red and appears in good condition. Thank you for any and all input!
