The clutch is the same across all 4.0 models including the pilot bearing. The fancy bellhousing from AA allows you to run the stock NSG crank sensor to stay with the adapted AX15 which communicates with the stock 05-06 flywheel, well, like stock. Since the clutch never changed between any of those models, you can bolt up everything else like it was stock once you have that bellhousing. The clutch release and all of that related stuff is the same year to year so none of it needs to be messed with. Just need an external slave AX15 and the AA bellhousing, and of course whatever else you want to do while you're in there, like a clutch or whatever else. Luk gold clutch seems to be pretty darn good.
