Hi all, I have a 04' TJ with the 5 speed. Like others my inner shift boot was destroyed, and the OEM ones were $150+.
This was too hard to swallow for me so I decided to 3D print an adapter ring from the 52109771AA boot used on 2003&04 TJs to the older boot used on the AX15/5 jeeps (OMIX 18886.95).
Thought it turned out really nice. Offers full throw of the shifter and fits very well, it does press against the center console on the right side but it's light enough I don't see this being an issue, there's no deformation.
I've seen some people use a mustang shift boot but wanted to keep it as clean as I could, I used the factory bolts for the bottom and captured nuts in the adapter plates to bolt the new boot on. The pictures are from a dry fit, didn't get any when I put it together for the final time since I was short on time, I used some RTV to make a good seal since the tub and around the bolt holes.
Let me know if anyone wants the STL or STEP, I can make some modifications to the design if anyone wants. And if you're really in a jam I'd print you one for a small cost over materials+shipping because it's dumb nobody has made an affordable aftermarket option for a wear part.
