I THINK THIS IS MY SECOND POST AND I HAVE BEEN LOOKING AROUND QUITE ABIT ABOUT THIS ON THIS FORUM AND OTHERS.
I have 2005 Rubicon 2 door inline 6 100k miles had her since 2018 automatic 42rle been getting CA emissions 4 o2 sensors :
Current Issue
p0031 p0037 p0051 and p0057 . I had these beginning in November its Jan been troubleshooting since then. 02 heater circuit low
Background
Only electrical mods I put in are a tranny gauge that I splicedin near the cigarette lighter I dont think should matter. However that was in Julyish of last year so its relatively recent.
Heater Blower Motor Resistor went out and I replaced with a non mopar part from autozone. Didnt think this should cause an electrical issue and I had these codes before that occasionally.
I had a trailer hitch light connector wire in between the fuel tank skid and the frame rub a wire and it seemed to blow the tail light fuse to so I used a butt connector and zip tied it up. That was around the time this started happening though and when i originally replaced the lights went out immediately and came back.
I have also received p0431 and each time I tighten up the pipes to the exhaust manifold at the flanges and it goes away. Unsure if this is related.
Had also received the p0700 and p0720 only viewable with obd reader not on the dash and replaced the OSS with mopar part and this was resolved! Typical at my milage and age I think.
2 years ago the fusible link burnt up when the polarity was reversed on a jump start in the dark. The fusible link has been replaced. Not sure if that fried something else in the wiring harness.
I am an electrical newcomer . I bought a mulitmeter and some aligator clip wires at harborfrieght and I stayed at a holiday inn last night.
Steps Taken to Troubleshoot So Far
So far I have done these tests https://www.obd2-code.com/2017/06/p0051-o2-sensor-2-1-heater-circuit-low-jeep-chrysler.html they all check out except I have gotten some resistance values at .5ohms not under .5ohms I think those are ok. There was no short to ground while sitting still (Inifinte resistance or open circuit i believe its called) Also did this while trying to move every wire i could no beeps made though on the multimeter). Original o2s were around 4.3 ohms which seems good but I replaced anyways as Im at 100k and had to replace one just rule them out. No high resistance in the positive to the pcm connector c2 and c3 as the wiring diagram indicates .5 ohms. Or in the ground wire .4ohms.
I cleaned off the ground points ( didnt change ground strap). That helped for a while but the codes came back 100s miles.
I have replaced the 02 sensors ( i knew that probably wasnt all 4 at same time but it was at 100k miles so I did it anyways). I had replaced one o2 some time back and the other 3 were original just replaced the other 3 codes pop up still.
I checked the ASD relay first time but it had resistance of 70 ohms and switched over when jumped and Im not sure its even in the circuit as its not in the CA version of the wiring diagrams.
What's Next
I think what remains that it could be is either
A. intermittent short to ground while moving ? Problems in the wiring harness I cant detect while still yet?
B. PCM @Wranglerfix or ares? any others I should consider
Any other things I am missing that it could be ?
If its A or B should i go to my local offroad extreme for 125$ an hour to see if they can find the short or try and replace the PCM from somewhere like wranglerfix.com or someone else. Would love to gain from other experience here and skip one or the other fees if I could?
Been reading alot about this on different threads with very few actual resolutions. Seems like the federal 02 heater circuit has a fuse and the asd relay in the wiring diagram but the CA wiring diagrams dont have any mention of a fuse or a relay or Power Distribution Center in them? Makes me think that maybe PCM is hosed because it doesnt have that fuse in the circuit to protect in case of a short.
Thank you in advance for any assistance.
Rob aka hoesindifferentobdcodes
Current Issue
Background
What's Next
