2000 4.0 with 187,000 miles. Here's my issue. I have the check gauge light/low oil pressure when engine is hot and at idle. I replaced the sending unit with a Mopar sending unit and still had the issue. Last night, I put in a T fitting and ran a manual gauge with the dash gauge. The pressures were reading the same between the two. The only difference is the manual gauge raised and lowered quicker with RPMs. At hot idle, my oil pressure is 8 psi. At running speeds, it doesn't get above 20 PSI when hot. On startup my pressure is at 60 and goes lower as the engine warms up. I replaced the oil pump about 5,000 miles ago. There is a slight tick to the engine when cold but quiets down when warm. What are all of your thoughts or suggestions in this situation.
Kevin
Kevin
