If it's flaking off, they probably didn't prep it right. The previous owner of mine sprayed the faded plastic with that stuff. Once it started flaking, I was able to power spray it with water to encourage further flaking. Be careful of the pressure as too much can take paint off and try to get an angle under a flaking area.
I take a little off at a time when I wash.
The problem is they normally use the stuff to cover rust and blemishes. So you may have body damage or faded paint underneath.
Try a couple methods and if the paint under it looks bad, you can stop or get more aggressive.
