Hello all, I am having some issues fitting my 2.5 OME springs. I loosened/removed everything that y'all have suggested and lowered my axle until the rotors are almost touching the ground. I have even jacked up on one side, used a spring compressor, and still cant get them in. I suspect I may not have the frame jacked up high enough because I am using 3 ton jack stands. I was considering going to get some concrete blocks or cinder blocks to put the jack stands on to hopefully be able to get enough height. I just dont want to break/bend anything and I also want to be as safe as I can be and not have the axle slide off the jack or have the frame fall off the stands. Any advice/suggestions?
@JMT @Chris
