This is a great picture for reference. It illustrates something that may be confusing to many people, especially if you're more of a visual person.
The exact reason why you cannot just buy shocks based on the "lift amount" listed by companies. The 5000X runs long, as an example.
We have all seen plenty of rigs with tall lifts, 33+ tires, and no bump stop extensions, or extensions that aren't correct.
That's how mine came compliments of the previous owner. A dropped pitman arm, 4" of lift, and literally zero bump stop extension. So yeah, I would say that assessment is dead-on accurate.
So based on what I see, the shock is not the correct size for the current set up? What size shock would be needed? A bigger or smaller shock? So if that’s a shock for a 4 inch lift, would you need a shock for say a 3.5 inch lift? Or bigger bump Stops?
Just for my own muddled brain clarification, the distance the shock can collapse must equal the distance from the steel bumpstop cup to the lower bumpstop surface, so the jounce bumper will stop it from collapsing that much...?This is a great picture for reference. It illustrates something that may be confusing to many people, especially if you're more of a visual person.
Disregard the soft jounce. Full bump is when the steel cup and axle pad touch.Just for my own muddled brain clarification, the distance the shock can collapse must equal the distance from the steel bumpstop cup to the lower bumpstop surface, so the jounce bumper will stop it from collapsing that much...?
That's what I said. Just making sure.Disregard the soft jounce. Full bump is when the steel cup and axle pad touch.
And neither of the other two pictures have a soft jounce, correct?For everyone to see, the soft jounce is designed to compress into the cup. The sole purpose of the jounce is to slow the suspension just before the smack of hard bump.
On mine, the jounces are removed for the purposes of setting up the bumps and shocks. They went back in once I was finished.And neither of the other two pictures have a soft jounce, correct?
I find it easier to focus on the compressed shock lengths and fitting it into that space. Then I go from there with the rest of the considerations.
