OK! I got the bracket installed and tightened down. I was able to get my other hand down there and use a finger to hold bracket in place while I got bolt started.
New issue is the Jeep won't start. It wants to but wont. Is this as simple as just an adjustment in the clocking of the unit or am I a tooth off?
Clocking relative to the engine block means nothing (unless there's excessive play in the camshaft gearing and/or timing chain). Sounds like you're out of position vis-a-vis the #1 cylinder being at TDC. Rotate the engine by hand until its at TDC #1, then check the OPDA internal clocking - the hole in the tone wheel needs to be exactly centered over the hole where the plastic dingus was - if you still have the dingus, see if it will insert. If it won't, then you'll have to pull the OPDA, re-align the tone wheel and try again. This is assuming of course, that its an OPDA problem to start with, but this will tell you.
That's my amateur diagnoses based on my understanding of the mechanical relationships involved. Others probably know more than I do!
