You traded one money pit for another!Ha Ha - well, there used to be a horse living in our garage. We sent her to live with our son. Now we just have the Baby Jeep.
So true! This one I can ride (Drive) though!You traded one money pit for another!![]()
Check the wiring at the connector. It's a pretty common TJ/LJ problem, where the wiring is frayed and/or corroded. Sometimes it's obvious, like this, and sometimes it's not.Complete.
In normal jeep project fashion...
One of the lights does not turn on when I hit the brights - will have to trouble shoot - hopefully it is only a bulb.
Thanks!Check the wiring at the connector. It's a pretty common TJ/LJ problem, where the wiring is frayed and/or corroded. Sometimes it's obvious, like this, and sometimes it's not.
Could also have been some corrosion in the bulb connector which got scraped loose during the bulb swap. Either way, good that it was a simple fix. Electrical stuff can be a pain.Thanks!
I troubleshot the issue by swapping the bulbs and now it works so I will stop messing with it until it starts acting up again. I have a feeling it is a wonky bulb as the wires look ok.
