2006 tj rubicon with a stroker and 42rle, the other day driving the Jeep on the freeway after accelerating a little a bit Later I experienced a p0301 check engine light difficult to tell but it might have been running just slightly rougher after the light came on. Drove on home and I reset the computer and everything seemed to be back to normal. Drove several days and on the day before taking it to the transmission shop to have the new tranny installed it developed a p0700 code, I wasn’t concerned about that one as I knew the transmission was having problems, the next day after installing the transmission the code reader At the shop displayed 4 codes related to the transmission but no p0301 at that time, they were all successfully cleared according to the transmission shop as any outstanding code would prevent programming the new transmission. Today, a day after picking it up at the transmission shop after accelerating from 40 to 60 quickly about 3 minutes later I got another p0301 and it was running a bit rough. I should have checked the injector then but reset the computer first, after 30 min. Reconnected the battery and it was running smooth checking the injector with a screwdriver that I slipped a jug with the bottom cut off onto the end of the screwdriver handel I could hear the injector firing normally.
what I have is, new engine, new transmission, new fuel pump, fuel tank pulled and scrubbed with the new engine, new plugs, new injectors, new throttle body, 2 year old coil, new crown opda 2 years ago, new O2 sensors 2 years ago, and a Wrangler fix 11 3/4 month old computer that is most of the new line-up, any idea as everything is pretty much brand new, if it was internal I’d think resetting the computer would have no effect I’m now wondering if it could be the computer?
