Searching the long start and p0456 code posts I don’t see the answer to my question - which is: will a leaking FP check valve cause a P0456 code to set?
my CEL started to light up about the time it began to take a few extra cycles to light off when cold. I have done Jerry Bransford’s “cycle the key prior to starting” and that does make a bit of difference. I have also checked the purge valve and canister hoses/connections in the engine bay ( I have an ‘01).
thanks for the insight folks.
