Hello all.
Installed a brand new warn m8000s on my '05 LJ. Did everything as described in the instructions. It was cold when I installed it (20 degrees or so). While installing the rope, I noticed the aftermarket stereo and amp installed by previous owner powered down and the check gauges light came on. I talked to a well respected individual about this and he said the battery likely didn't have the CCA for all the accessories. I noticed the voltage gauge is no longer working and it has a p0516 code. The battery shows 14v when the Jeep is idling.
1. Could the winch taking too much of the voltage have caused the code?
2. Could the code or the winch have damaged the gauge?
3. Is it likely the electrical issue is in the PCM?
