So the CEL came on and the reader says it's a 1391. Cam or crank sensor. So I clear it and go around the block. Didn't come back on until I get the revs up around 3k+.
Back in the driveway I went to unplug the cam sensor to check the connector and it moves around. Like it is really loose. Several turns with my fingers to get the bolt on the hold down clamp finger tight. So I figure I found the problem...but...timing must be somewhat 'off'.
Do you set timing on the 4.0l the same way you would with any engine with a distributor? Timing light or vacuum gage and just turn the sensor like it was a dizzy?
