that LSD is supposed to be seamless operation
That is what I was told too, which is why I went that route.
Or swap out the SYE for a SS SYE and a longer rear driveshaft. I know, it's all expensive attempted solutionsYeah, @Alex01 has a spare NP231 he just took out in lieu of an Atlas, which we are currently discussing. It's a lot of work to do that only to find it's not it. After I get this re-gearing fiasco sorted out, I may try playing with lowering the t-case skid and more pinion angle dialing before I venture into all the work of swapping t-cases.
its interesting that a thicker skid affected the vibes, how is your trans mount old/new/poly/rubber?
Where do I measure? When I ordered it, I measured center of yoke to center of yoke.
during the week I'm in Mountain View working and staying in Morgan Hill on the weekends I'm 30 to 40 minutes from there.I replaced the trany mount with a Crown stock replacement after replacing the skid. I also replaced the motor mounts with ones I got from @JMT, which had lower miles on them. That is when I installed the MML. Oh, as I mentioned earlier of adding a MML. The reason I did that was because I had previously lowered the t-case skid 1" experiementing, which resulted in the biggest reduction in vibes to date. So, to keep the t-case skid back up on the frame where I wanted it, I installed the MML to mimic the drop in the t-case skid. It worked.
How far a drive are you from Citrus Heights?
mine with the original set up was 4.5" SL, standard SYE circa 2000, Adams DCDS, and no vibes period, no TC drop no MMLHad I known then what I know now, I should have just went with the SSSYE to begin with. I just didn't think I would need it only having a 3" lift. I also didn't want to deal with the speedo healer.
I think my Adams is the same length and you are welcome to try it to eliminate possible issues I also have a front that worked with a Dana 30 to 23115-7/8"
I can't go back much farther with the rear end as my track bar is only 1/4" away from hitting the fuel tank skid.
That's a great idea. I may use that tonight.have you checked pinion angle at the yoke U-joint mounting surface? I clamp a square to mine and extend it along side the DS then I zero it on the DS and read the difference on the square. I find this to be the best way to measure pinion angle cause if you forget to take it off you will know the first 6" of travel.
I can practically whiskey-eye it that way...Or scotch if that’s your preferenceWhy don't you head ov
Silver liningGuess that would stop me from losing digital angle finders down the road, lol!
