I need a chain and maybe bearings? Where to buy and what brand? Should I do bearings and seals while it is out? 144k miles on the odometer.
I think he's looking for the chain inside the NV241OR transfer case.Are you talking about the NV241OR Rock Trac from a TJ Rubicon? They are somewhat rare and expensive so be prepared to spend $1500-2000. Depending on the mileage it has on it, probably needs nothing unless it’s leaking fluid or damaged
From your posts, I get the impression that you are fairly mechanically inclined and certainly not someone who gets fooled by the shit others tend to repeat.Edited for clarity. I'm pretty sure I need a chain. Last time out it seemed to skip teeth. Is it okay to just replace the chain or should the sprockets be replaced at the same time? Should a replace the bearings while it is apart? Who is a good vendor for this?
Mine is still in pieces from that endeavor. You know anyone wants a side job putting it all back together? I'll probably fuck it up if I do it.built mine from a 5 gallon bucket of parts. did a writeup. might help you out. i think i had some parts suppliers listed in it as well. HTH.
https://www.google.com/amp/s/Jeep Forum/forum/f9/241or-assembly-scratch-3534050/?amp=1
and if im not mistaken i offered to put it back together when i brought you the planetary back and you declined...ill do
cmon blaine i remember exactly what we pulled apart and it took 30 seconds to pull 10, 10mm bolts out. thatd be the easiest thing you work on all day! ill bring the rtv and put it back together next time im up.
I've seen you work.and if im not mistaken i offered to put it back together when i brought you the planetary back and you declined...
looks like the links not workingThanks @mrblaine for your reply. I have never been into a t-case, but it makes sense that the case around the chain is no bigger than it has to be. Last time out something definitely felt weird a couple times. It could have been the type of rock on the trail.
I'll start with a fluid drain amd see what comes out.
@Bigmac I'll check out your thread too.
Just remember , there’s not a 100 percent deal it’s the shaft . Likely , but it can be a harmonic that only is present when both ends turn , it can be backload from the shaft on the transfer case chain that’s now out of play , or something up front the shaft was transmitting .Well, in another thread @AndyG suggested pulling out the front driveshaft to rule out the DC joint causing noise. I pulled it last night and the noise disappeared along with a slight vibration. It looks like I'll be working on that and not the T-case.
