ptmt86 New Member Original poster Joined Sep 28, 2018 Messages 8 Location Maryland May 28, 2019 #1 Question.... My passenger side parking light is out. But the passenger blinker light works fine. I've changed the old bulb with two new bulbs. No luck. Any ideas? Thanks.
Fixer6 TJ Enthusiast Joined Oct 12, 2018 Messages 602 Location United State of Texas May 28, 2019 #2 Maybe
Daryl 2004 Rubicon Supporting Member Joined Apr 29, 2018 Messages 3,269 Location 🌎 May 28, 2019 #3 Remove the bulb that’s not working. Clean the contacts with a brush. See if it works. Not recommending this exact brush, but using it as a visual aid. AES Industries Light Bulb Socket Cleaning Brush https://www.amazon.com/dp/B00480N2P8/?tag=wranglerorg-20 Reactions: Fixer6
Goatman TJ Expert Supporting Member Joined Apr 23, 2019 Messages 5,040 Location Upstate NY May 29, 2019 #4 If the blinker fluid doesn't work try upgrading to the Headlight Fluid. Just make sure you have protective gloves and mask while using it. Reactions: Fixer6
