Thanks man, I'm trying to get it done so I can enjoy the local trails over winter before we move up north and they are no longer in my backyard (almost quite literally!)...
For the 408, I used the SCAT Forged rotating assembly but actually used the LA style pistons since my deck was perfectly square and didn't need to be squared up. This resulted in 0.008" stick out (most Magnum pistons are in the hole some, so you have to zero-deck the block), which I compensated for with a slightly thicker Fel-Pro SD-series head gasket. Total SCR is about 10.3:1. Heads are Edelbrock 2.02" aluminum Performers. For the cam, I originally went with a mild "RV" style cam from UTAwesome Performance (Marty is the Magnum king!) but decided to save that for the 5.9L I was building for my YJ at the time. I ended up using a Comp Cam P/N 20-604-9 with an advertised duration of 264º/274º and .512/.512 lift.
I was hesitant to go bigger or with a lower LSA (this one is 112º) since I do need to keep this truck emissions friendly. On a non-stroker, this cam is right on the cusp of potentially causing sniffer-test issues, but with the bigger cubes I was fairly certain that it would be fine. Everything else is typical high-performance build stuff (roller rockers, double-roller Cloyes chain, Pacesetter ceramic shorty headers for driveline clearance, etc.). I kept the factory intake, since I need to have it match the VEIC during emissions testing every 2 years. I'm also on the factory throttle body, but only temporary (I am sending off to Rolf S. for boring out to 52mm blades).
Overall I'm happy with the performance. She starts and runs butter smooth in traffic but will light up 37"s like it's nobody's business with just a blip of the throttle. I have already pissed off a Tacoma driver and 2500 GM Brodozer at the Loop 202 on-ramp
That said, without a tune, the last thing I want is to burn a hole in a piston so I really haven't pushed it too hard
I had some parts delays last year, then we took a family vacation the week before COVID hit (almost got stuck in Maui!) and then everything went nuts. By the time I got all the pieces together, summer had hit and it was well into the 100ºs. It's 65º out today and should be cool from here on out, so I'm extra focused on trying to get the TJ done so I can turn my attention to the RamCharger. I'm in the process of converting the OBD-I setup for a 97 JTEC OBD-II setup. This will retain the "look" of OBD-I (at least as far as the visual inspection goes) but will provide better emissions control while also allowing for handheld tuning via a SCT (I'll be using Marty at UTAwesome for that). My long term goal is to build a stroker G3 Hemi for the RamCharger and move the Magnum stroker to the TJ (while converting to an auto).
