I got an AHP 201XD. I was hoping to get the new Vulcan 205 but it's delayed until May or longer now. SO far it welds very well for me. The foot pedal has been updated. But the bummer is the Rotoflex torch doesnt take standard 17 consumables, so I can't try my new gas lens kit I got. I'll upgrade the torch to a CK flex head here when I get better. I suspect it's the same base unit as the Everlast and HF.
You will definitely want a TIG for that. Spool guns aren't clean and precise enough IMO for work like you're talking.
I wouldn't call it extremely steep, just takes a steady hand. I'm digging it, I like how precise it is.
The weld area above was cleaned very well, you can see the line I used a brush, and I use alcohol, not acetone. I'll clean up the box when I'm done fabbing.
I've been practicing on little coupons, and I can get into the a perfect position. Welding this box was tough because I was standing, and didn't have a TIG Finger yet. I was pretty proud to be able to weld whole sides of the box in on pass. The one above was one pass with no filler. I used filler on some of the other edges, playing around.
