I tried the grease trick with no luck, I have a tight fitting rod and it is building good pressure, but the bearing won't pop.
Then I found this pic on this forum:
My LUK kit only came with the inner needle bearing. Is this entire sleeve supposed to be removed/replaced or am I just trying to get the needle bearing out?
Any clarification would be much appreciated.
Thanks!
Thanks!
