Looking for advise on pinion depth based of gear pattern. I think I need to shim but wanted to check first. Any insite is appreciated.
Yes that is a little shallow. Try adding at least .005 and see what happens.
Remember that you are looking for center from root to crown and not heal to toe. You are right at being to
deep now so I would pull .002 and get the backlash above .007 and I think
Remember that you are looking for center from root to crown and not heal to toe. You are right at being too deep now so I would pull .002 and get the backlash above .007 and I think you are golden.
is this a high pinon or low pinion axle?
