So guys, if he decides to plasti-dip his wheels, should he remove his outer wheel weights, first? I see that he has 'em. I'd have concerns about plasti-dipping something that is a separate part from the actual rim, as there is a gap between the wheel weight and the rim, even if minimal. This could create a place for peeling to start. Conversely, if he removes the weights first, he'll almost surely scrape the plasti-dip reinstalling them, and create a place for the peeling to begin. (*If you do remove the wheel weights, be sure and mark exactly which ones went where so you can reinstall them without messing up your tire's balance.)
