What's better for bleeding brakes after replacing parts - positive pressure or vacuum? Looking for a DIY 1 person device
I recently replaced front calipers/pads/rotors (installed black magic kit) including extended lines, also replaced right rear line.
Until I found/created a leak in the right rear line I had the front bleed and seemingly working with good pedal pressure.
Suddenly I had no pedal pressure and found a leak in the right rear line being the cause.
Now that's replaced but getting no pedal pressure, I believe it's from a thing in the system that blocks fluid from going into the 'leaking' system.
So I either need to push fluid into the system (specifically the right rear) or pull it.
Any advise on which method to use
tia
dave
tia
dave
