I’m having problems out of my engine rpms being higher than normal at a given speed. (30 @ 4K rpm when it would normally be 3k, 50 at 3.5-4K where it would normally be 3, etc. I have no noticeable slipping or chatter when shifting. First is a bit rough to pull out in when a/c is on but not bad when off (stock 2.5 with 4.10 gears and 32x11.5)
Curious what other issues it could be.
If it is the clutch would I be better off buying the luk kit, a flywheel and clutch release bearing at the same time?
