He's not the only guy getting good fuel economy
. I'm more than double what I was getting previously and I'm driving pretty normal now.
How are you doing the fuel pump stuff for the Kubota? I have been really looking at fuel systems lately, since I had to get fuel to the Cummins, but also I had a lift pump issue on my truck and I'm swapping out all of the OEM stuff, probably this summer.
There seems to be small stuff that pops up when doing fuel tank stuff, especially for diesel. My OEM tank went back to whatever that stuff is called that handles the gas vapors, which is unnecessary for diesel and I grabbed some cheap diff vents for those lines. I'm not 100% sure on the best method, but I tried no vent and got some diesel spilling when I was full and going off road. Then I closed it off and never had an issue, but when I took off the gas cap you could tell there was a vacuum. I assume on a long trip that vacuum could mess with fuel delivery but I don't know.
I commented on your YouTube comments, but I really like that you're going to try a stock setup first to see if it'll work. HP is mostly about passing so I figure you'll be fine, but I forgot the torque numbers and curve stuff you mentioned earlier.
