As I understand from what Blaine told me when he helped with my install, it's inside the steering gearbox itself.Alright, out of the box first question. Where is the “steering torsion bar” on a jeep TJ? Google produced ads by Currie.
So I found a small cooler with 1/2” NPT fittings and AN 6 fittings. I can adapt to the 3/8” or 5/16” return line to make everything clean.
This seems like a very small cooler, with restricted fittings (i.e. -6AN). Of course I'm only basing this on Blaine's recommendations, which included:So I found a small cooler with 1/2” NPT fittings and AN 6 fittings. I can adapt to the 3/8” or 5/16” return line to make everything clean.
Fluid flow is fluid flow. You can make the system more restrictive or less restrictive. We prefer less restrictive since things tend to have fewer issues that way. Doesn't mean a more restrictive system won't work, they do, just not every time.I don’t really want them to design a plug and play system. I did not request that they list a hydro assist on there site that is TJ specific. That said, they do have (2) listed. I bought one. When I talked to a “expert” there, he never mentioned a cooler. However using my own deduction and ir heat gun, I decided to ask here.
Now that I realize you are actually speaking of a custom system for my TJ, I will reread until I understand what you are saying. I’m not saying you are not clear, it is my lack of expertise on the current subject.
Thanks for the input and time!
The grass for padding?Here is how I mounted my coolers on the V brace.
They have worked for the 5 years mine was running.
That looks simple enough, no overheating problems?Here is how I mounted my coolers on the V brace.
Working on that post count?The grass for padding?
