Juggernaut
Flex a lite and Derale just to name 2 manufacturers that instruct to install near the upper hose entry to the radiator, others make a fitting to install in the thermostat housing. Oems measure temp at waterjacket temps not the lower radiator exit for fan control/OBD purposes.Which manufacturer?
You know, anyone can throw a kit together with chinese parts and call themselves a "manufacturer".
I found a deal on craigslist for one of them there flexalite E fans. $100.
Fan is oem quality.
Controller= shit box leaking diarrhea
After much research, I discovered that the only purpose for a fan being there at all is to service the radiator, not the engine.
When you are traveling at 50 mph the ram air through the radiator is much higher than a fan could produce. In that state the fan should be off.
If you measure the water temp at the engine exit the fan will run at 50 mph.
The way the manufacturer suggests would make the fan operation a function of engine rpm.
The way I suggest, makes the fan operation a function of cooling necessity. The fan only operates when increased heat needs to be dissipated from the radiator.
In 80* F weather, idling my fan runs 20 sec on, 100 sec off.
When I'm moving above 15mph it stays off unless I rev the rpms up past 3500.
Over 30 mph it stays off 100% of the time.
Also, a fan will wear out faster the longer it operates continuously.
Think about it.
My fans operate the same as yours and are not rpm dependent at all. They are generally off at highway speeds unless unload and only switch on and off otherwise to stabilize engine temps about 210 degrees as it should. Question for you: how is meauring the engine temp at the engine exit going to make the fan run at high speeds or rpm dependent with the programmable controller?
