While I have been trying to diagnose various items on a new to me project Jeep (01, 6cyl, 5 speed), one of which is a possible bad clock spring. I have several symptoms that indicate that may the case. While trying to source a part, I was working on some other items and realized there may be more issues with my horn (it’s currently not working). I found a blown fuse under the hood and went to install a replacement and the horn started going off. After reading some additional threads on horns, I thought I could have a stuck horn switch. I pulled the airbag/horn button off to see what I could test. I did a continuity test on the red and black likes seen in this photo which I believe go to the horn “switch” and had continuity. I’m assuming you shouldn’t have that if the horn button is functioning correctly. Am I assuming correctly?
