Also, the inner bearing looks good.
Now I need to check the yoke, measure the shims and start removing, and then tightening with the old nut.
My question is the following:
Let’s assume that the pinion depth is good. Then I play with shims (start removing) till I get the preload of 6 to 10 inch pound when tightened to 200 feet/pound? After I hit the right shim amount and width, with right preload , then I install back the carrier and verify the pattern with gear marking compound?
Let’s say the Pattern is good, then install the seal, tighten the new nut, verify preload and call it a day?
Seems like I have total of
3/1000 inch shims - 3 units
5/1000 inch shims - 1 unit
10/1000 inch shims - 4 units
30/1000 inch shims - 1 unit
Total preload shim width is 3x3+5+10x4+30=84/1000
Seems a lot of shim to me.
The yoke looks like it will be ok. I would dress the ends of the splines with a triangle file and the end of the yoke with some wet dry on a piece of glass or other known flat surface to make sure there are no burrs. I am not so sure about that inner bearing though. Can you post pics of the races?
Definite signs of being run loose and moisture in the oil. Personally if it is something you drive a lot I would go through the effort of replacing the bearings. If it is more of what is referred to up here as a "Village Rig" then get everything cleaned up and back together.
I drive it to errands, weekend fun, maybe to national park. Don't drive it to work, have new asian car for it.
Do you think that it will live for next 30K miles, or given the state of the bearings it is too much to ask?
I ended up with removing 16/1000 shims in total, and now at 200 feet/pound I get preload of 8 inch/pound. When I remove 19/1000 shims in total, then I get too much of preload.
Never thought that 1/1000 of inch shim matters.
OMG. Just measured the preload - there is pretty much none, maybe 1 or 2 (really stretch, more like 1) inch pounds.
The problem is that the pinion nut actually does not seem to be lose. This means that or bearings are shot, or the shims somehow expanded themselves, or it was installed incorrectly in the first place.
Reading through this thread, my guess is that your bearings need replaced.
As BJ mentioned, not healthy, but not uncommon either. When an axle has a lot of miles, the preload (bearings) wears down. I see it a lot where there isn't any preload whatsoever.
Yeah, 0.001 does matter. Removed additional 0.001, and got excessive preload (20 inch pound) already when torqued to just 150 feet pound. I guess, adding back the 0.001, and buttoning up everything.
I will check the gear pattern. If it load 0.016 inch in preload shims, I guess it would have impact on the on the pinion depth - the inner bearing got eaten up slightly, I assume.
The point is that these gears have maybe 10K miles on them.
Did you run a pattern before taking stuff apart? To be honest, if you aren't doing a full re-gear, then I'd put it back the way it was. Did it have any issues (other than very low pre-load) is was presenting? If not, put it back they way you found it and that will probably be your best chance for success. If you tighten up the preload now, the used bearings will wear differently and it could lead to bearing failure.
The best case with out doing a full re-gear, is to replace all four bearings and leave all the shims in their original position when putting it back together. If you aren't going to change anything out, then leave everything as it is.
Lastly, if you are going to replace the bearings, then you need to account for the baffle behind the inner race as you will most likely destroy it when removing the race. They do sell that as an individual item.
Oh, I didn't realize that. I thought we were dealing with high mileage. I would take them back to the shop and have them correct it. If that isn't an option, then adjust preload and send it. No need for a pattern or anything. It's already been established and work hardened.
