Yeah, 0.001 does matter. Removed additional 0.001, and got excessive preload (20 inch pound) already when torqued to just 150 feet pound. I guess, adding back the 0.001, and buttoning up everything.
I will check the gear pattern. If it load 0.016 inch in preload shims, I guess it would have impact on the on the pinion depth - the inner bearing got eaten up slightly, I assume.
That doesn't sound good at all. Sounds like a complete rebuild to me now.
Pinion depth and pinion preload have to be established in the correct order. Because the pinion depth is controlled by shims and baffles under the inner pinion bearing and race and the pinion bearing preload is controlled by the preload shims under the outer pinion bearing you must have your gear pattern established first as any change in pinion depth will have an effect on how many shims it takes to get he correct pinion preload.
From what I read, the backlash is supposed be under 0.01 inch.
Where did you read that?
Let me know if I am looking at the wrong table
6-10 according to that chart. The .001 is showing that the measurement is in thousandths of an inch. So the spec according to your chart is 6 to 10 thousandths of an inch.
My worst case backlash appeared to be 12 thousands of an inch. I know it is outside of the spec, but is it really so bad got front axle? 95% of time I am in 2WD,
That is not an unrealistic spec for a used gear set.
All things considered I thought it would have been worse. I would not mess with it just deal with the bearings.
