I know there are MANY threads on this but wanted some advice on another 5.3 swap. Seller has a 2016 5.3L Chevy L83 out a Silverado. Engine has 29K miles on it. Originally purchased for a swap in his JKU but things changed. Price is $2500 for motor alone with full harness and compter . Has an 2017 8L90E with it and the transfer case for another $2K. Trans has 20K miles on it. From what I have seen for an engine with that mileage the price for the engine is good.
I have a 2000 TJ that I am wanting to do this swap in. I do minor crawling as my build is just getting going. Currently have Dana 30 Front with Lockrite locker, and Dana 44 rear with Detroit Truetrac. Running 4.56 gears. 4.5" lift with SYE and new Rear driveshaft. Currently still running stock axles.
My questions are:
1.) Would any of you run the 8L90E in a TJ?
2.) Seller is not sure but I assume this still has the cylinder deactivation on it. Any idea on how hard this would be to remove?
3.) f I do not buy the 8L90E what transmission do you believe would be best for an L83?
4.) Ideally would like to keep the Dana 44 rear and just upgrade axles but what would you suggest for the front? Ford HP Dana 44 I know is nice but hard to come by. Would that work the Dana 44 Rear I have? Dont remember widths on each.
Thank you in advance.
My questions are:
