I'm also new to the Jeep family...so take it easy on me 'til I get up to speed.
Here are initial impressions. Insights welcome.
Starts ok, a little labored. Battery tested 12.33 cold and 14.07 running. I'm concluding for now that alternator is fine and battery weak. I'm in Minnesota so weak battery in the winter is bad news. I'll replace.
I'd appreciate insight on how to address rust, primarily the structural rust:
1. Is the car road worthy?
2. Are those cracks on frame?
3. On the assumption the rust indicated on the frame is rather serious, what are effective and reasonable financially solutions?
Brakes: Feel very soft. Build sheet indicates power front/rear drum. I see no specific mention of ABS. Do I have that right? Obviously I'll pull wheels and check brakes, calipers and rotors and likely replace them all.
Steering: Feels rather sloppy.
Key: I only have one key. it's black "cover." Do I have a "sentry key immobilizer system"? Where can i find replacement keys?
No Soft top. Are these reliably easy to come by (I'd need a storage solution for the hard top).
If this is worth fixing up, what are some mods I should consider? One that comes to mind is upgrading the headlights. Also need floor mats (hardly critical though).
Thank you!
Thank you!
