Hello everyone! New to the TJ forum (but not forums) and am hoping to get some help on a 1997 TJ I'm looking at. I've been searching on here and Wrangler Forum but can't quite find what I'm looking for.
So I pulled a build sheet and it lists Customer Preferred 2TD and 25D. I've seen some things that says the 25D would include the Dana 44 rear. The Jeep does have a 44 rear. However, the build sheet also says 3.07 gear ratio. And I understand the 97 only came with 3.07 or 3.55. The tag on the rear axle lists 3.73. The front is confirmed as a Dana 30 with a 3.73 tag as well. The current owner hasn't had it all that long but said it was nearly stock when he got it and did a bunch of restoration and refresh work. He said in his work on it, some things seemed to be from a 1998. It has a clean title, which doesn't always mean that it hasn't had any major problems.
Is it possible that it's a late 1997 that just got some 98 parts on the line? It has a build date of 05/97.
Thanks for any help and hoping to be in a TJ very soon! Maybe this one?
