Hello folks, I'm back in the TJ game after 5 years off. This is my 4th TJ (5th Wrangler) and with luck, my last!
I scored a beautiful Silver Rubicon with ZERO mods, dual factory tops, 25K miles, in excellent condition. Guy had never even locked the axles (had to test them out before I bought it). I'm excited to make it mine, but I'm trying to keep from messing it up too much. My goal is to run 33's, yes, I'm set on 33's. I've never been happy with anything but 33's and now that I've driven a Rubi with 4.11's and the 6-speed I desperately want larger tires, lot of shifting with 31's. My last TJ had a 2" BDS SL and 1.25" BL combo, even with 33" KM2's it rode excellent. I'd be fine to re-create that as it came out the way I like it. I have one additional requirement for this Jeep that I didn't have for the previous, that is no drilling. My goal is to keep everything bolt on so that I can return it to stock later if I choose. When I say this thing is untouched, I mean it, it's had the battery replaced and that's ALL! If the gears weren't so low I might just leave it alone. Kind of ironic as I really wanted a Rubicon so I could run 33's without a re-gear.
Question 1. I previously ran the OME (2" lift) rear track bar relocation bracket and it centered the rear axle perfectly, BUT, it required drilling. I know lots of folks here recommend the Currie adjustable rear track bar. I don't mind dropping a little coin on it if I HAVE to, but wanted to gather opinions first. I see this $400 hit as a way to avoid drilling that bracket. Is there any other adjustable rear trackbar that will do the job for less? On-road manners are VERY important to me, so I'll pay to play if I have to. Just wondering if I have to go all out just to center up the axle, keep a smooth ride, and avoid drilling. Off-road flex would be nice, but it admittedly takes a back seat to my goals.
Question 2. If I decide to add a 1" BL like I did before, I may want to venture into tummy tucking. Or I may decide to go with 3" springs instead for a more athletic look. I've read about what needs to be done to run a rear CV driveshaft (new spring perch location, shock mounts, track bar position, and even rerouting the exhaust). This sounds horrible to me, but I would love a CV driveshaft. Question is, if I only tuck the T-case a little, or go to a 3" SL, how much pinion angle before this becomes a can of worms? I'm pretty picky about the set-up, don't want to drill (and definitely don't want to weld), so what kind of total lift of the T-case are we talking before things get crazy on the rear axle? By lift, I mean combine spring and T-case raise. If the 3" SL requires less of a pinion angle I would prefer that, I don't mind buying a few adjustable CA's if needed (as long as my ride comfort isn't affected)
NOTE: I have done the BL and MML to correct for vibes previously. I'm prepared to do it again if needed but will try and avoid it for now (didn't like messing with the console and shifters). With the lower T-case on the Rubi, I'm starting to get conscious of the belly and don't want to exagerate it with a BL if I don't have to. I've already ordered 2" BDS springs (loved the ride quality with these) and will start there. I may get a 3/4" front puck and maybe a 1/2" OME rear puck to give a tad bit more clearance if needed. Previously I had 33's on prior to the 1" BL and it looked okay, but not great.
Congratulations if you made it this far. I'll try and keep things shorter in my future posts!
