Since I'm planning some upgrades, I figured I'd get some measurements of the stock setup including the driveshaft and pinion angles.
Here's what I measured for my stock 05 Sport with no changes to driveline or suspension:
The first question is, do the numbers look like they're in the right range for a stock Jeep, or should I go back and measure things again? I tried to follow the best descriptions of how to measure these angles and measured twice, but it is my first time doing it.
The second question relates to the FSM, which provides three "rules" for drive shaft angles:
But my operating angles are 5.7* at the transfer case output and 4.9* at the axle input. My setup should be just what came from the factory, so what gives? Is the FSM "rule" on operating angles too conservative?
- Good cancellation of u-joint operating angles (within 1*)
- Operating angles less than 3*
- At least 1/2 of one degree continuous operating (propeller shaft) angle
