2005, 4.0, 3.73 gears, 6-speed, Dana 35 rear…. I’ve been researching my next project a little bit, and I figured I would get some opinions from you guys….. I am wanting to get some sort of locking diff or a LSD for the rear. I have read a lot of good things about the Eaton TruTracs, and I am kind of leaning towards that based on price, and reviews.
Most of my driving is on road, with a wheeling trip every few months. Typically no rock crawling, but more so deep ruts/washouts, hills, and southeastern mud.
WHAT I KNOW:
WHAT I KNOW:
- I’m not ready for a regear.
- I am not swapping axles.
- I would like to maintain good on-road performance, while gaining traction off-road (I’m tired of hammering the throttle off-road because of my open diffs).
- I do not want to break the bank for a selectable locker.
- I am only planning on locking the rear.
- Using a LSD, should I upgrade to chromoly shafts? I know the answer will be “yes”, so does that shaft upgrade require any further upgrades to make them work, or is a straight up plug-and-play (pull the old shafts out, put the new ones in)?
- Some of the videos I’ve watched appear to show the TruTrac not engaging as the other wheel loses traction - or it appears that the Vehicle still has open diffs as it loses traction. This is until the driver changes the technique, and stops and applies the brakes. That seems weird to me. I would think that the LSD would engage the other wheel to pull as you apply more gas and the one wheel loses traction - I would think that’s it’s an automatic thing as one wheel spins, the other engages. Seems counterintuitive to have to stop in the middle of the obstacle, apply the brake, and then start again to get the LSD to work (I also don’t fully understand how a LSD works, so there’s that).
