That's what I was running with my 4.0. With the supercharger I was not a fan of the sound (way too much rushing air sound like an air boat). With the 4.0 NA it was alright. I think the stock LJ muffler is still quieter.Good info! Is this what you're running @toximus?
I'm assuming that when it comes to quiet mufflers it simply comes down to size and how much packing it has inside?
I run a thrush welded, I’ve had people ask what V8 I swapped in.I would think so. I had the thrush "welded" muffler before which is essentially the same thing, but with no packing. It was a nice sound, but too loud for me. The Hush was the perfect compromise, good sound, but between 2-3k rpm all I hear is the engine whirring away like an angry massey ferguson![]()
That actually isn't true. The space where a muffler can fit is limited to about 4" in diameter and 20" long overall which includes the bits for the exhaust pipe to attach to. If you want to get technical, you can fit a muffler that is 8" wide at one end, 4" wide at the other and the total length can not exceed 20".Any muffler shop will be able to set you up with a generic quiet muffler. Just tell them you want it to be quiet and they'll make it happen.
That will be difficult. I had 4.0 one time and we played with different mufflers testing something for a project and the one common theme with all mufflers was unfortunately drone.My main concern is as minimal drone as possible, that while hopefully reducing sound to some degree.
304 Stainless Steel it is...I'm glad to see this thread. I'm debating whether a new exhaust or rear suspension work is next in line. I hate my muffler--It is loud and drones. (Can't read the brand unless I drop the skid--that's for another time. The current muffler is about 22" long and 4" in dia. straight through.) The PO welded the entire exhaust into one piece off the exhaust manifold. Getting it on and off to do the RMS is easily the least enjoyable work I've done so far on my Jeep.
My next exhaust needs to be as quiet as possible, as rust resistant as possible, and very easy to take apart in sections.
Are multiple v-band clamps a good idea?What version of stainless steel has the best experience (e.g., 304, 409)
All I know is that the shop in Baja made it happen for $50 out the door and it was whisper quiet.That actually isn't true. The space where a muffler can fit is limited to about 4" in diameter and 20" long overall which includes the bits for the exhaust pipe to attach to. If you want to get technical, you can fit a muffler that is 8" wide at one end, 4" wide at the other and the total length can not exceed 20".
It fell off pretty quickly but that was a rocks fault.
Im running the 2 pre cats with no third cat and a spintech. It drones so loud between 2 and 3k rpms ive started keeping earplugs in the jeep.I’ll be having a spintech put on my LJ in next couple weeks. I don’t expect quiet given the series I went with but are others which supposed to be quiet and at 4” x 6” x 12” I believe is smaller.
